MWOODSON | -- 10-15-2015 @ 9:42 AM |
I just got a 46 Ford 1 ton truck. The hood was just placed on it. I am looking for a detail diagram of how to install the hood correctly. Any suggestions? Along with the necessary bolts. Thanks Marie
jal9846 | -- 11-10-2015 @ 10:26 AM |
See attached picture...there is some special fastners that attach the hinges to the Hood in the rear...I believe they are 1/4" fine thread hex bolts with a low hex head. The spring supports attach using shoulder bolts...the upper one ot he hood panel being a round head slotted bolt, and the other for spring support to cowl being a hex head shoulder bolt. Roy Nacewitz at Fordoldbolt.com is a good resource for the correct hardware.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=9079 |
