jimmyjazz | -- 08-24-2014 @ 2:16 PM |
I have a 1940 original ford truck half ton it has the reverse switch and 3 leaf springs in rear I was told this is a 3/4 ton set up can anyone tell me?
alanwoodieman | -- 08-24-2014 @ 4:14 PM |
sounds like a 4 speed non syncro transmission. extra spring leaves do not make it a 3/4 ton but a wheelbase of 122" can. from 1938 up, Ford did produce a 3/4 ton and a 1 ton truck-wheelbase 122" Does your truck have a 112" wheelbase, frame with a X cross member ,enclosed driveshaft? if so 1/2 ton. 122" frame with open driveline is a 3/4 or 1 ton truck-would require more info to determine which
flatheadman | -- 08-25-2014 @ 8:12 AM |
My 1939 122 inch tonner has an enclosed drive line, parallel rear springs and 17 inch wheels. Also the gas tank is under the seat in the cab.
alanwoodieman | -- 08-28-2014 @ 3:55 PM |
40 was a change year for Ford trucks--went to open driveline on 3/4 ton and up, ladder bar frame, still has gas tank under seat
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=7650 |
