Bruce W | -- 11-23-2014 @ 8:56 PM |
I've got two flathead V8 crankshafts. I'm certain that one of them is a Mercury as it has "1CM" cast into one of the counterweights. The other has nothing visible. Is there any way to ID it other than to set it up in a block or "V"-blocks and measure the stroke? They're both sure to be '49-'53 cranks, because of all the flathead parts I used to have, I never had anything earlier. Thanks. Bruce W
52Ragtop | -- 11-24-2014 @ 4:25 AM |
http://www.flatheadv8.org/boomer/crank.htm should help
Bruce W | -- 11-24-2014 @ 3:20 PM |
Thanks 52, that will give me something to go on. Looks like the only way to be sure, tho, is to set it up in blocks and measure it. Bruce
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=7941 |
